Grafana v9.2.2 Windows 11 -
Design a simple table, being each row a different HTTP request, extracting a couple of fields as columns and being able to rename string fields and make calculations with number fields. -
Using table panel. -
What happened?
I find it too hard to make each new field extraction and renaming. -
To have more freedom to customize each output. -
This is why I got, but I guess there might be a more appropriate visualization to do this.
