Editable Table Visualization
I would like to know if there is a way to make the table visualization editable?
What do you mean by that? A table panel should be as editable as any other panel.
I mean being able to edit/delete the data displayed inside the table. To make the table interactive.
Surely the whole point of Grafana is to display information which is contained
in the back-end data store, according to the queries you set up.
Why would you want someone to be able to edit the displayed value so that it
no longer reflects the back-end data?
Antony.
Hi Pooh,
Thanks for the reply, that makes sense, are you aware of a dashboard object that would enable me to insert data from grafana dashboard into a database, something like an html form?
I would also to support this feature.
Grafana is a powerful tool to visualize data.
If there would be a chance in the future to also edit data (with restrictecd user roles) it would be phenomenal.
BR
Phil
