Hi guys, I was just wondering if there is a way to add a column into a table where I/the user can manually edit text on the table itself; essentially, a “Notes” column.
Cheers
Cheers
Welcome
Where would these notes be stored at?
Hi there @yosiasz ,
Currently all information in the table is stored in a SQL database. After some more research, I’m not sure what I want is possible; I want this column to be specifically editable via grafana rather than having to edit the SQL db and then refresh the grafana page.
Hope this makes sense. Cheers.
I think apache echarts grafana plugin has that feature
@yosiasz It’s a Data Manipulation panel if I understand the question:
@jacobharris There is no way to update it directly in the table unless creating a custom plugin.
To update the data we created the Data Manipulation panel to use a form and interact with API. Here is the video explaining the concept:
Love the
siren sound effects
Does not take away from amazing product
Perfect! Thank you very much @mikhailvolkov
@jacobharris There are multiple examples of how to use it and more videos on YouTube.
You are welcome to ask questions in the repository.
