Manual Data Entry in Dashboard
Is there any way in Grafana to create a panel where user can manually input data?
I need to visualize some calculation which will be based on existing data and user-defined data (i.e. production data x day-price (day price needs to be inputted manually).
Having a table-like panel where user can input any numerical values would be much helpful. So far I couldn’t find any plugin/panel which supports this.
Hello @adriantaw23 , even I am trying to do same thing. Did you find any plugin or any other workaround?
Sourabh
Give a try to Infinity data source plugin.
