Why does my table panel show a dropdown of each time series instead of showing up as a table row?
The query is a grafana loki query.
Hello @kyrogue, your Loki query returned multiple series. You can use Outer join transformation to combine series into 1 table.
Thanks, however when I do that another issue occurs, additional columns are added instead of instead of appearing under the same column(pid,datetimeDiff):
I have the labels to fields Transform due to converting the logql query labels to fields, which is different from yours
You can then try merge transformation:
