I have 2 dashboards. In the first one there is a table such as
| pod | metric1 | metric2 |
| aaa-1 | Two | Three |
| aaa-2 | Two | Three |
| bbb-1 | Two | Three |
If I drill down clicking on any value of the pod column then the dashboard 2 is opened passing the pod name. This works great so far.
What I need to do is to have a dynamic link. e.g.
- if pod == aaa* then open dashboard 2
- if pod == bbb* then open dashboard 3
Is it possible? if yes how can I do it?
any solution is appreciated (even if I have to add a hidden column with the dashboard link calculated at runtime and use the value of that column to drilldown)
thanks
