Drilldown from table cell to dashboard/panel
I’m pretty new in Grafana and I’m pretty lost… I’m using Grafana Zabbix plugin. I’m using a table which shows some Zabbix metrics (for example network interface utilization, 100 bps). I would like to have an option which would enable drill down to a graph which shows this metric, from selected table cell (100 bps). Drill down would take me from the cell to a new panel or dashboard which would display graph. Is there a way to do it? How to create dynamic URL which would make this drill down procedure possible?
Thanks in advance!
Regards
