Switch stack series for all panels in board
What Grafana version are you using?
  • v8.5.27
I want a easy switch for stack series for all panels in board. Best way could be a custom variable with two options
  • normal
  • 100 %
Panel type is always Time series.
I do not found any easy solution, which I can use for a board with many panels.
I you have an idea, let me know.
Thanks!
sounds like a good use of a variable.
you can choose the look and feel, and behaviors of the variables with this plugin as well:
He won’t be able to use the Business Variable plugin for Grafana since the minimum supported version seems to be Grafana >=9.0.0. But sure, he can use variables in general.
any reason you are still on v8?
I have other dependencies and it is not in my decision to update Grafana version. If I could update, I would do it :smiley:
So today I need a solution or workaround with version v8.5.27.
Thank for replies!
