We are Grafana v7.5 with RHEL OS
We have a dashboard, There are multiple panel inside it. On the top of the dashboard we have variables displayed. Based on a specific variable selection we want certain set of panel widgets to display.
Can you please help if there is a feature which makes above requirement feasible.
Hi @ankit1mishra,
What you need to configure is some sequence of chained variables:
Doing so can make dynamic dashboards like this:
https://play.grafana.org/d/cvDFGseGz/graphite-templated-nested?orgId=1
I would take a look at those queries and the variable configurations and use that as a starting place
We are already using chained variables. I want to show/hide panels based on variable value
