Grafana 8.1.3 -
I have a Custom variable with predefined set of values. This variable is multi-value and I can select a subset of the values from the list. I need to repeat the row for SOME of the selected values and ignore the rest even if the value is selected. -
I’m trying to create a variable derived from the first one, and use it for repeating the panels/rows. -
What happened?
So far I don’t know how to achieve the task.
Hi @dkuzminov1
Have you read our documentation on creating chained variables?
