Dynamic Panels (show and hide Panels depending on the selected variable)
Hi, I’m working with Grafana v11.3.0 + influxDB.
I’m trying to create dynamic panels. So I create a custom Variable e.g (a1,a2,a3,all).
For each Variable i have one Panel. Now i want if i choose the variable e.g. a1, that only one Panels appears and the other should be invisible.
Do you have any Idee how i can achieve this?
Thanks for your help.
you cant hide or show panels based on variables unfortunately
Is there an other way to achieve something like that?
Maybe with a python skript?
i guess you could try replace dashboards with provisioning using the api, but i have not tried this
yes I think I have to try it with the Grafana API.
Thanks for your reply
You could do this with business chart plugin
chrome-capture-2024-11-15
