Is there any way to hide a panel in Dashboard?
Hi Team,
Is there any way that i can hide a panel this is the panel(Business Text) where i wrote a JS for validations.
Is it using the plugin? I didn’t understand whats mentioned in the post
yes this plugin
But i am using another plugin whixh does some other task. Cant i do the same my existing plugin?
Which plugin are you using
I am using business forms with java script which does some validation. And i want to hide it
I am confused. Is it business text or business form you want to hide?
Want to hide business text. But my question is also generic. Is there any way to hide any panel?
Hide it based on what trigger
I want it to be hidden always can i be done?
