I have this settings:
- linux redhat 7.6 (Maipo)
- grafana-6.6.2-1.x86_64
- elasticsearch-oss-7.2.0-1.x86_64
- metricbeat-7.2.0-1.x86_64
I have created a dashboard for specific ApplicationName for monitoring and sending alert of more specific filesystems on two hosts
The alerting configuration of this dashboard works fine (sending mail and other trap) and the alerting is visible in the “alerting rule” of Grafana.
Now i have a two question:
- If possible create an global dashboard with status(red/yellow/green) of my Application and with drill down on ApplicationName see the detailed alerting messages of filesystem dashboard or process dashboard and more?
- How to group a list of servers under a single label?
Because right now with “Alert list” visualization on create dashboard section, i have only possibility to view directly all alert (with customization on Filter section), i have see the option “Alerts from this Dashboard” but when enable this features all the alerts disappear and the word “NO DATA” appears.
Thanks for answer and attenction of my issue.
Regards.
