I’ve been making dashboards for individual hosts and they’re coming out great, but as Grafana does not yet support alerting on templated variables (it sounds like a hard problem to solve), whats the best way to go about making a panel that alerts on, say, high disk usage across all volumes on all hosts?
My naive approach is to make a big graph panel with my query, in this case (Influxdb):
SELECT mean("used_percent") FROM "disk" WHERE $timeFilter GROUP BY time($__interval), "host", "path" fill(null)
And then alert on when its greater than 75%. This works, but the visualization is pretty dense for anything over 20 hosts with 2 volumes each and it seems like this might be a bit expensive to run. Is there a better way to do this that scales better? Thanks!
