Suggestion for bar chart
Hello everyone,
I don’t now where can i make suggestion about upgrade for future update so i make one here.
In time serie it’s possible to select a time periode by selecting it direclty on the time serie.
But it look like it’s not possible with a bar chart, is it possible to do it and i just miss it, or maybe it should be add in a future upgrade.
Do you have time dimension in your “barchart”? How is defined that “barchart” - is it barchart panel (so no time dimension):
Or is it timeseries panel (so time dimension is there) and it is only visualized in the bars?
Yer this got me too when I was first started so I had to rebuild a lot of our dash from “bar chart” to “time series”.
If your data has time series, use “Time Series > Bars style” and not the “Bar chart”
From Grafana Play below:
But the thing i don’t like is that the bar are stack,
However for simplicity i need bar next to each other, wich i succesfully made with barchart but not with time series with bars style
it’s a Barchart panel type, i have a ‘timestamp’ data wich i use for time dimension
So that’s a reason. You are expecting timeseries panel feature in different panel type.
Suggestion: try to find another panel type, which have everything what you need
Yeah I have faced this dilemna too as the time series does not have an effective side-by-side bars.
How many bars do you have?
As the workaround I have done for mine is to play around the alignment and group the bars that can be logically stacked.
Time dimension or month/date derived from date time data value?
