Status / Heat map for every result (not time)
Hello dear community,
i looking for plugin which will show results / statuses in status map visualization mode but not by time but for every test.
For example: Tests are run “randomly” 5 times per day and i need to show only five blocks with colors green / yellow / red.
Please, it exist plugin which works as above described functionality?
Thanks for any answer.
Okay, i found it…
For my requirements is the best choice Status Dot Plugin.
