I would like to customize the existing Status History visualization panel.
Since it is a built-in panel I am not sure how to proceed since i can’t just fork the repository.
Do you have any suggestions on if this is possible?
I’ve tried:
Create base plugin with grafana plugin tool
Clone the grafana repo and copy the status-history plugin into my barebone plugin
There are just so many imports from @grafana/ui that are missing that i can’t get things to run. I assume these components are probably not meant to be imported by plugin devs
So right now the panel shows a square with a certain color that represents a status at a given time.
I need the possibility to represent multiple statuses in a single square.
For example:
For 00:00 query A has status OK - Green
For 00:00 query B has status BAD - Red
This would split the square in 2, half green and half red
If we had 4 queries we would have 4 colored squares per timestamp.
In our team we still use an old grafana 7.3 client because we developed a custom multistatus map plugin (in angular js) which is a fork of the flant/grafana-statusmap plugin.
That plugin was archived and their developers recommend using this new status-history plugin, that is why i was looking to see if i could adapt it to “multistatus-history”
Another option would be to rewrite the angular plugin we have now into react to see if we could use it in new grafana versions
