As I notice ‘Status Panel’ plugin is almost dead in development. Looking for replacement.
Any suggestion ? Requirements the same - changing colors according to query results.
Thanks
Did you try the stat panel, there is still the community Status Panel that is being updated (last update 4 months).
Hope it helps.
Good Luck
Sorry but almost no changes in code for 3 years.Just small bug fixes for 6.7 and 7 version
Would you explain what you are trying to visualise, I bet you would find the right visualisation in Grafana
Good Luck
