Statusmap not displaying
Hi all,
Anyone else having a problem with the Statusmap visualization plug-in in the last few days? Mine just shows a blank panel now. If I go into edit mode it shows the same until I click to select the Statusmap visualization again and then it displays like it should. BUT exiting back to the dashboard causes it to go blank again whether I save the change or not.
Statusmap v0.3.2 Up to date
Grafana Version 7.2.0
I have the same issue. Grafana 7.2 and Statusmap 0.3.2. I use this extension for a critical monitoring task and right now it is showing a blank screen. Editing it and going to the query panel causes it to show no query data. I cannot even get it to show up temporarily as the previous commenter.
I appreciate the corroboration. I just found that a 0.3.3 exists. Looking up how to update it…
Never mind. Same issue.
I also installed it but it still showed as 0.3.2 - not sure it is an actual newer release.
I just took a look through the 3.3 code and it still identifies as 3.2. And that the update isn’t “properly” published makes it seem the developer isn’t very serious. I’m not aware of a viable alternative.
On my Ubuntu server I did a:
apt-get install grafana=7.1.5
and it is working again. Clearly something in 7.2 broke the plugin. For me I am sticking with Grafana 7.1.5 until the plugin developer fixes his code.
I’ll stay with 7.2 for awhile and see if the dev fixes it. But it’s good to know you found a solution that works for you. :+1:
Seems like v0.3.4 fixes it for me.
Me too. Thanks for the heads up.
