Hello
i have a Stat Plugin, showing the Uptime of a VM, works so far!
because the Name is system.last or with a Alias it would be system.alias
i just wished to use the Overrides Display name and add the new name like VM108
i got a error and No data
other Stat Plugin i could change the name on the same way
@grant2
your link is correct
so the stat Plugin showing system uptime don’t like the override.
the stat Plugin showing available apt update, the override works well.
and it is the same stat Plugin i use
the text is just overriding with Alias
have a nice day
vinc
