Hello.
Grafana docker: Grafana v8.0.6 (68fe9e3431)
Host OS: Ubuntu 20.04.2 LTS (GNU/Linux 5.4.0-80-generic x86_64)
Graph: Time Series
I have two queries. When I don`t have series override, when I click on one series in the legend, the graph displays only it, when I click on the second, the graph displays only the second. As it should be.
When I add Override with Display Name, and rename both series, and click on the legend both are hidden and shown at the same time.
How can I have custom Display Name for each series, and the legend to still work at the same time?
Best regards.
Hi @kvasilev
This sounds like a bug. I would report in the repo so the teams can track and fix it
screenshot your settings please
the override settings + the result youre seeing
Hello.
Here are the settings of the Time Series:
Here are my queries to the influx using the flux language:
Here are my graphs without clicking on the legend:
And here is the same graph, when I click on the Difference in the legend:
P.S.:
I have the " |> map(fn: (r) => ({ r with _value: r._value / 1000000.0}))" because I cannot have the same units on the both ( right and left ) Y axis. I had opened a separate topic for this.
this will definitely mess things up. The teams are working on this, but right now I think you can only depend on using multiple y axes when each one uses a different unit
