Need clarification on grafana display part
Hi ,
I am using grafana 10.3.3
I have a single panel where I am showing different time-series data .
I want to customize the tooltip as per my need to identify individual graphs separately .
How to customize the tooltip in grafana ?
Thanks,
Nilanjan
You can use fields override to hide some series from the tooltip (and also legend and hide it completely):
Any reason why can’t you create multiple panels?
Hi ,
Thanks for your response.
From the panel, I am making a REST call and from the response I am extracting three different fields for display ( Start Time ( Time ) , Value ( Number) & Name ( String ).
Currently , when I display the data in time series graph , the tooltip only displays the Time & Number field.
My requirement is to also add the Name ( String ) field in the tooltip.
I tried adding the the Name field in field override , but I am not seeing any tooltip property.
Please let me know how to achieve this.
Thanks,
Nilanjan
You may try this Time Series+ plugin. See an example and discussion here.
Just to confirm - what is your datasource (Infinity perhaps?). Also, can you share a screenshot of how your graph looks like now?
If something like this:
You could try using Partition by value transformation
And change the display name to ${__field.labels.name}
