Grafana V11.3.1 under Win 11 querying InfluxDB V1.6.7 under Ubuntu (other PC).
Two SQL queries, each for a single variable from the same database table, both correctly visualized as Time series.
Added an Override, added there Properties: Axis/Placement - Right, Axis/Label, Standard Options/Unit. Dashboard was saved and refreshed.
No change on the graph at all.
Anybody any advice, please?
In this screenshot you have two Grid V on chart, not Grid V and Grid I:
How does your data look like in a Table view?
The legend was originally/automatically “V” and “I” according to queried variables. I changed the Display Name - both were renamed. I suppose that the override should have changed the second one.
Table View: I can change a displayed variable between V and I. I think there is nothing that can be affected by the Override.
I have created a new dashboard from scratch and added an Override immediatelly even for the first variable. It works. The problem has reoccurred under some circumstances but it is solvable by a similar way.
