Try with this one i have try to use it with a new server and it works fine,
"annotations": {
"list": [
"builtIn": 1,
"datasource": "InfluxDB",
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"limit": 100,
"name": "Annotations & Alerts",
"showIn": 0,
"type": "dashboard"
"description": "general test",
"editable": true,
"gnetId": null,
"graphTooltip": 0,
"id": 1,
"iteration": 1612518109922,
"links": [],
"panels": [
"datasource": null,
"fieldConfig": {
"defaults": {
"color": {
"fixedColor": "yellow",
"mode": "fixed"
"custom": {
"align": null,
"filterable": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "yellow",
"value": null
"overrides": []
"gridPos": {
"h": 4,
"w": 2,
"x": 0,
"y": 0
"id": 8,
"options": {
"colorMode": "value",
"graphMode": "area",
"justifyMode": "auto",
"orientation": "auto",
"reduceOptions": {
"calcs": [
"last"
"fields": "/.*/",
"values": true
"textMode": "auto"
"pluginVersion": "7.3.6",
"repeat": "bucket",
"repeatDirection": "v",
"scopedVars": {
"bucket": {
"selected": true,
"text": "test",
"value": "test"
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"orderByTime": "ASC",
"policy": "default",
"query": "buckets()\r\n |> filter(fn: (r) => r.name == \"${bucket}\")\r\n |> keep(columns: [\"name\"])",
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Bucket",
"transparent": true,
"type": "stat"
"datasource": null,
"description": "",
"fieldConfig": {
"defaults": {
"color": {
"mode": "thresholds"
"custom": {
"align": null,
"filterable": false
"displayName": "${__field.labels.host}",
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "rgb(42, 46, 42)",
"value": null
"overrides": [
"matcher": {
"id": "byRegexp",
"options": "/.*dead=\"false\".*/"
"properties": [
"id": "thresholds",
"value": {
"mode": "absolute",
"steps": [
"color": "dark-green",
"value": null
"matcher": {
"id": "byRegexp",
"options": "/.*dead=\"true\".*/"
"properties": [
"id": "thresholds",
"value": {
"mode": "absolute",
"steps": [
"color": "dark-red",
"value": null
"gridPos": {
"h": 4,
"w": 21,
"x": 2,
"y": 0
"id": 4,
"options": {
"colorMode": "background",
"reduceOptions": {
"calcs": [
"mean"
"fields": "",
"values": true
"textMode": "name"
"repeat": "bucket",
"scopedVars": {
"bucket": {
"selected": true,
"text": "test",
"value": "test"
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "import \"influxdata/influxdb/monitor\"\r\nimport \"experimental\"\r\n\r\nfrom(bucket: \"${bucket}\")\r\n |> range(start: -10m)\r\n |> filter(fn: (r) => r._measurement == \"system\")\r\n |> filter(fn: (r) => r._field == \"uptime\")\r\n |> group(columns: [\"host\"])\r\n |> monitor.deadman(t: experimental.subDuration(d: 15s, from: now() ))\r\n",
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"timeFrom": null,
"timeShift": null,
"title": "Host",
"type": "stat"
"alert": {
"alertRuleTags": {},
"conditions": [
"evaluator": {
"params": [
0.1
"type": "lt"
"operator": {
"type": "and"
"query": {
"params": [
"A",
"5m",
"now"
"reducer": {
"params": [],
"type": "avg"
"type": "query"
"executionErrorState": "alerting",
"for": "5m",
"frequency": "1m",
"handler": 1,
"message": "Host down",
"name": "Alert host down",
"noDataState": "no_data",
"notifications": [
"uid": "UhSyu8YMz"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"datasource": null,
"fieldConfig": {
"defaults": {
"custom": {
"align": null,
"filterable": false
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 1,
"w": 24,
"x": 0,
"y": 4
"hiddenSeries": false,
"id": 6,
"legend": {
"alignAsTable": false,
"avg": false,
"current": false,
"hideEmpty": false,
"max": false,
"min": false,
"rightSide": false,
"show": false,
"total": false,
"values": false
"lines": false,
"linewidth": 1,
"nullPointMode": "connected",
"options": {
"alertThreshold": true
"percentage": false,
"pointradius": 3,
"points": true,
"renderer": "flot",
"repeat": "bucket",
"scopedVars": {
"bucket": {
"selected": true,
"text": "test",
"value": "test"
"seriesOverrides": [],
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"query": "import \"influxdata/influxdb/monitor\"\r\nimport \"experimental\"\r\n\r\nfrom(bucket: \"${bucket}\")\r\n |> range(start: -10m)\r\n |> filter(fn: (r) => r._measurement == \"system\")\r\n |> filter(fn: (r) => r._field == \"uptime\")\r\n |> group(columns: [\"host\"])\r\n |> monitor.deadman(t: experimental.subDuration(d: 15s, from: now() ))\r\n |> map(fn: (r) => ({\r\n time: r._time,\r\n host: r.host,\r\n dead : if r.dead == true then 0 else 1\r\n }))",
"refId": "A",
"select": [
"params": [
"value"
"type": "field"
"params": [],
"type": "mean"
"tags": []
"thresholds": [
"colorMode": "critical",
"fill": true,
"line": true,
"op": "lt",
"value": 0.1
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Alert",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "short",
"label": null,
"logBase": 1,
"max": "1.1",
"min": "-0.1",
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"refresh": "5s",
"schemaVersion": 26,
"style": "dark",
"tags": [],
"templating": {
"list": [
"allValue": null,
"current": {
"selected": true,
"text": [
"test"
"value": [
"test"
"definition": "",
"error": null,
"hide": 0,
"includeAll": false,
"label": null,
"multi": true,
"name": "bucket",
"options": [],
"query": "buckets()\r\n |> filter(fn: (r) => r.name !~ /^_/)\r\n |> rename(columns: {name: \"_value\"})\r\n |> keep(columns: [\"_value\"])",
"refresh": 2,
"regex": "",
"skipUrlSync": false,
"sort": 1,
"tagValuesQuery": "",
"tags": [],
"tagsQuery": "",
"type": "query",
"useTags": false
"time": {
"from": "now-6h",
"to": "now"
"timepicker": {},
"timezone": "",
"title": "eureka",
"uid": "EZbB-JLGk",
"version": 14
