Hopefully my title made sense!
I am making a power dashboard, and I am stuck on something. I have a tile there which is a stat panel and I want it to show current power input. Its the one that says “100% Solar” in the screenshot
I’d like this to switch between the following possible options
- 100% Solar
- Solar + Grid
- Grid Only
- Portable Generator
- Standy Generator
The 100% Solar and Solar + Grid are easy, as I just have value mappings to display that text based on if I’m exporting power to the grid or not
But, getting the rest are pretty tough. I can’t figure out how to do it. I have inputs that show the wattage of each items, and I have the logic worked out
- IF “Main” is a negative value, then display “100% Solar” and be Green in Color
- IF “Main” is a Positive Value and “Solar” is over 50w, show “Grid + Solar” and be Yellow In Color
- IF “Main” is a Positive Value and “Solar” is less than 50w, show “Grid Only” and be Red in Color
- IF “Main” is under 50w and “Portable” is over 50w, show “Portable Generator” and be Purple In Color
- IF “Main” is under 50w and “Generac” is over 50w, show “Standby Generator” and be Orange In Color
Does it sound possible to do this? I am using InfluxQL, but if I need to use Flux to get it done, I will
