OSS 11.1.2 -
I try to set panel stat colors based on value that I have from another query. In tried to do this in similar way I can do this in table panel. So I select two queries and I do override like on screenshot. But I can’t manage to work it on stat panel. It works only with non-dynamic values and simple thresholds or value mappings.
This is screenshot how I did it in table panel.
I want to make this field on left red and as only visible field in this stat panel
