I’m sure this is a very basic function but I cant for the life of me find the answer.
I want to display the results of a health check on a couple of different sub systems.
I wish to display this info dynamically as a number of squares with the names of the sub systems as the displayed text in each square, and with a colored background based on if the health check was successful or not. I am using a stat panel.
I have the information needed in my query. I however fail to combine the two so that one provides the text and one the color. I have succesfully gotten it to dynamically display my data and provide colors based on the result, I simply fail to then change the title of the stat square to another field. There is just one query.
Anyone able to help?
I’m running on Grafana v11.2.2 if that matters.
Here is what it looks like today
And here is my (dummy) data:
I want to for example display check if level > 5 and change the color accordingly, while always displaying for example the value in “value”.
Edit:
Thank you @sowdenraymond for the solution!
In short, this is what needed to be added:
Together with appropriate Thresholds/Value Mappings
