Showing the value of a field in the graph but using the value of another field for colors in a Stat panel
I am trying to create a Stat panel while using Grafana 8.4.1 that shows the result of a field in the center of the panel but uses another field to color the panel.
Example:
Using the following query:
SELECT 'test' as text, 1 as metric
I want to show:
Test being the field “Text” and the field “metrics” used to color the background of the stat panel green.
Ever find a solution to this?
any workaround or solution for this one?
