Hi Guys.
After an upgrade i have a problem with my stat panels. Before it, if i used the following filtering:
I got the value WITH the name of the host on the panel:
After the upgrade, if i filter to exact host, the hostname is not showing, only the value:
What is the recommended way to filter to a host and show the name of it on the panel?
If you want to show the hostname value in your function add setAlias($__zbx_host)
To filter the field by host name or by Host too in your query.
I advise you to put /.*/ in your Host so that you can filter on the dashboard by clicking on the hostname in the legend for the timeseries panel for example.
Or cool thing with Polystat plugin
Oh hell. Thanks. Its works.
