Hello everyone,
I’m trying to display the server hostname using a text-mode query in Grafana, but I’m facing an issue when using the Stat panel. The name option does not appear in Value option > Fields, which prevents me from displaying the hostname correctly.
I’m using Grafana v11.5.1 with the Zabbix plugin v5.0.0, and my Zabbix server is running version 7.2.3. I’ve checked the documentation and some forum posts but couldn’t find a solution.
Has anyone encountered this before or knows a workaround?
Thanks in advance!
