I have following query:
SELECT last(“physical_consumed”) *$CPUprice FROM “cpu_util” WHERE (“host” =~ /^HOST/) AND timeFilter GROUP BY time(__interval) fill(none)
Min time interval
1h
Relative time
now/d
Time shift
1h
I have a variable to choose hosts from.
What I’m looking for is to choose several hosts and summarice them into one.
I’ve tested it, but the result doesn’t get correct.
I created a question that do the cost so far/day. And I suspected it should do host1+host2…
But it seems as it takes the latest data from each. So if I have for example 11 hours it takes 6hours from the first host and 5 hours from the second host and so on.
I’ve tested Singelstat Math Panel, but that’s manual adding of hosts.
Is there anyone that might have a clue to solve it?
b reg Niklas
