I want to create a dashboard similar to this:
I got this dasboard using stat panel. However I want to display in each panel a variable that corresponds to the host value inside of the panel. That is instead of total, that is the name of the field, I want to display a grafana variable’s (I only got that in the title of each panel (H1, H2, H3) )
But the value that corresponds to total fiels has to persist in order to keep the color variation.
Is it possible in this stat panel? There is a better way to resolve that?
Thank you
- Grafana version: 9.2.1
- Ubuntu
- I am using grafana with prometheus.
