HI
In the mobile version, the menu icon and the dashboard name overlap.
Is it possible to fix this?
HI
Hi @daeunjeong,
Thank you for sharing this feedback. This may be an issue based on the version you are using, can you confirm what version you are on?
Our dev team tested out the latest version and they cannot recreate the issue you have are having.
Thank you!
Thank you for your reply.
The current version I am using is v8.5.3 (409e9bc9a5).
Does a version update make it better?
Hi @daeunjeong,
Thank you providing that information. Yes if you upgrade to the current version you should no longer experience that issue. You can find that here: Download Grafana | Grafana Labs.
Let me know if you run into any other issues.
