Drop down dashboards overlapping
I have difficulties to describe or search my issue. So i’ve insert some pictures
Wenn i drop down a dashboard, it looks like this:
but when i colapse the dashboard, it looks like this:
instead of everything collapsed and no graphics shining through
how can this be fixed?
this is how it should be;
Sorry for that, seems frustrating, i think something going wrong with the JavaScript.
Which version are you using ?
Can you open a console on your browser and check for js errors there.
Good Luck
pluginVersion": “7.4.0”,
Are you using any specific plugin on one of your panels ?
I suggest you do an elimination process to identify which panel is causing issue,
Create a copy of your dashboard and remove one by one and test.
Good Luck
it’s only one Dashboard causing this.
As you can see with my “should be” screenshot, i have other dashobards with doesn’t have these issues. As those dashboards are from grfana download dashboards, i’m nit sure how to procede. i can try to fix java errors though.
I suggest you try to recreate it from the JSON.
Good Luck
Is this error something i can fix with installing some missing plugin, or is this a code error within JSON?
It’s a reference to the text panel plugin, it maybe a corruption of the plugin, you can try an upgrade of your environment.
Good Luck
i found the solution. Whenever i modify the dashboard within the grafana gui, the display gets scrambled. When i use the original json and make my modifications directly in the json file and import afterwards. It eworks
