Version is 10.2.3, system is Centos 7 -
I imported a zabbix template into my Grafana dashboard. -
What happened?
The panel with layout of “Table” is not display correctly. -
It supposes to look like this:
template url as below:
Zabbix - Full Server Status | Grafana Labs
