Hi @agnestoulet1 thanks for your response.
Here it is: usually the problem starts after the fifth panel:
"content": "<div><h3 style='color:yellow'>Site: <span style='font-weight: bold;'>Department</span></h3> <p>Node: XXXX </br> Interface: Unit: 1 Slot: 0 Port: 2 Gigabit - Level </p></div>",
"gridPos": {
"h": 3,
"w": 6,
"x": 0,
"y": 0
"id": 0,
"links": [],
"maxPerRow": 2,
"mode": "html",
"repeat": "",
"repeatDirection": "",
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "text",
"scopedVars": {
"datasource": "Customer - SolarWinds - JSON",
"cacheTimeout": null,
"colorBackground": true,
"colorValue": false,
"colors": [
"#d44a3a",
"#F2495C",
"#299c46"
"description": "OSPF protocol status metric \nNode: XXXX\nInterface: Unit: 1 Slot: 0 Port: 2 Gigabit - Level · NeighborIP: x.x.x.x",
"format": "none",
"gauge": {
"maxValue": 100,
"minValue": 0,
"show": false,
"thresholdLabels": false,
"thresholdMarkers": true
"gridPos": {
"h": 3,
"w": 2,
"x": 6,
"y": 0
"id": 1,
"interval": null,
"links": [],
"mappingType": 1,
"mappingTypes": [
"name": "value to text",
"value": 1
"name": "range to text",
"value": 2
"maxDataPoints": 100,
"nullPointMode": "connected",
"nullText": null,
"postfix": "",
"postfixFontSize": "50%",
"prefix": "",
"prefixFontSize": "50%",
"rangeMaps": [
"from": "null",
"text": "N/A",
"to": "null"
"repeat": "",
"sparkline": {
"fillColor": "rgba(31, 118, 189, 0.18)",
"full": false,
"lineColor": "rgb(31, 120, 193)",
"show": false
"tableColumn": "value",
"targets": [
"hide": false,
"refId": "A",
"target": "SELECT ProtocolName as metric, ProtocolStatus as value, NodeID FROM Orion.Routing.Neighbors Where NodeID = 17 AND NeighborIP = 'x.x.x.x' AND IsDeleted = False" ,
"type": "table"
"thresholds": "5,7",
"timeFrom": null,
"timeShift": null,
"title": "OSPF",
"type": "singlestat",
"valueFontSize": "30%",
"valueMaps": [
"op": "=",
"text": "DOWN",
"value": "1"
"op": "=",
"text": "Attempt",
"value": "2"
"op": "=",
"text": "Init",
"value": "3"
"op": "=",
"text": "TwoWay",
"value": "4"
"op": "=",
"text": "Exchange Start",
"value": "5"
"op": "=",
"text": "Exchange",
"value": "6"
"op": "=",
"text": "Loading",
"value": "7"
"op": "=",
"text": "FULL",
"value": "8"
"valueName": "current",
"options": {}
"gridPos": {
"h": 3,
"w": 2,
"x": 8,
"y": 0
"id": 2,
"links": [],
"options": {
"showThresholdMarkers": true,
"showThresholdLabels": false,
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"mode": "thresholds"
"title": "Transmit"
"overrides": []
"orientation": "auto"
"pluginVersion": "6.6.2",
"repeat": null,
"targets": [
"refId": "A",
"target": "SELECT TOP 1 OutPercentUtil FROM Orion.NPM.InterfaceTraffic WHERE NODEID=17 AND InterfaceID= 121 ORDER BY DateTime DESC",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"gridPos": {
"h": 3,
"w": 2,
"x": 10,
"y": 0
"id": 3,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Receive"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"target": "SELECT TOP 1 InPercentUtil FROM Orion.NPM.InterfaceTraffic WHERE NODEID=17 AND InterfaceID= 121 ORDER BY DateTime DESC",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"gridPos": {
"h": 3,
"w": 6,
"x": 12,
"y": 0
"id": 4,
"links": [],
"maxPerRow": 2,
"mode": "html",
"repeat": "",
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "text",
"scopedVars": {
"colors": [
"#d44a3a",
"#F2495C",
"#299c46"
"description": "OSPF protocol status metric \nNode: XXXX-XXX\nInterface: Unit: 1 Slot: 0 Port: 2 Gigabit - Level · \nNeighbor IP: x.x.x.x",
"format": "none",
"gauge": {
"maxValue": 100,
"minValue": 0,
"show": false,
"gridPos": {
"h": 3,
"w": 2,
"x": 18,
"y": 0
"id": 5,
"interval": null,
"links": [],
"mappingType": 1,
"mappingTypes": [
"value": 1
"value": 2
"nullText": null,
"postfix": "",
"prefix": "",
"rangeMaps": [
"from": "null",
"text": "N/A",
"to": "null"
"repeat": "",
"sparkline": {
"full": false,
"show": false
"targets": [
"hide": false,
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "OSPF",
"valueMaps": [
"op": "=",
"text": "DOWN",
"value": "1"
"op": "=",
"text": "Attempt",
"value": "2"
"op": "=",
"text": "Init",
"value": "3"
"op": "=",
"text": "TwoWay",
"value": "4"
"op": "=",
"value": "5"
"op": "=",
"text": "Exchange",
"value": "6"
"op": "=",
"text": "Loading",
"value": "7"
"op": "=",
"text": "FULL",
"value": "8"
"options": {}
"gridPos": {
"h": 3,
"w": 2,
"x": 20,
"y": 0
"id": 6,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Transmit"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"gridPos": {
"h": 3,
"w": 2,
"x": 22,
"y": 0
"id": 7,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Receive"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"content": "<div><h3 style='color:yellow'>Site: <span style='font-weight: bold;'>Department</span></h3> <p>Node: xxx </br> Interface: Unit: 1 Slot: 0 Port: 2 Gigabit - Level · xxxx </p></div>",
"gridPos": {
"h": 3,
"w": 6,
"x": 0,
"y": 3
"id": 8,
"links": [],
"maxPerRow": 2,
"mode": "html",
"repeat": "",
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "text",
"scopedVars": {
"colors": [
"#d44a3a",
"#F2495C",
"#299c46"
"description": "OSPF protocol status metric \nNode: XXXX-XX\nInterface: Unit: 1 Slot: 0 Port: 2 Gigabit - Level · L2L_XXXX\nNeighbor IP: x.x.x.x",
"format": "none",
"gauge": {
"maxValue": 100,
"minValue": 0,
"show": false,
"gridPos": {
"h": 3,
"w": 2,
"x": 6,
"y": 3
"id": 9,
"interval": null,
"links": [],
"mappingType": 1,
"mappingTypes": [
"value": 1
"value": 2
"nullText": null,
"postfix": "",
"prefix": "",
"rangeMaps": [
"from": "null",
"text": "N/A",
"to": "null"
"repeat": "",
"sparkline": {
"full": false,
"show": false
"targets": [
"hide": false,
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "OSPF",
"valueMaps": [
"op": "=",
"text": "DOWN",
"value": "1"
"op": "=",
"text": "Attempt",
"value": "2"
"op": "=",
"text": "Init",
"value": "3"
"op": "=",
"text": "TwoWay",
"value": "4"
"op": "=",
"value": "5"
"op": "=",
"text": "Exchange",
"value": "6"
"op": "=",
"text": "Loading",
"value": "7"
"op": "=",
"text": "FULL",
"value": "8"
"options": {}
"gridPos": {
"h": 3,
"w": 2,
"x": 8,
"y": 3
"id": 10,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Transmit"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"gridPos": {
"h": 3,
"w": 2,
"x": 10,
"y": 3
"id": 11,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Receive"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"content": "<div><h3 style='color:yellow'>Site: <span style='font-weight: bold;'>Department</span></h3> <p>Node: XXX </br> Interface: Unit: 1 Slot: 0 Port: 1 Gigabit - Level · XXX </p></div>",
"gridPos": {
"h": 3,
"w": 6,
"x": 12,
"y": 3
"id": 12,
"links": [],
"maxPerRow": 2,
"mode": "html",
"repeat": "",
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "text",
"scopedVars": {
"colors": [
"#d44a3a",
"#F2495C",
"#299c46"
"description": "OSPF protocol status metric \nNode: XXX-xxD\nInterface: Unit: 1 Slot: 0 Port: 1 Gigabit - Level ·XXX\nNeighbor IP: x.x.x.x",
"format": "none",
"gauge": {
"maxValue": 100,
"minValue": 0,
"show": false,
"gridPos": {
"h": 3,
"w": 2,
"x": 18,
"y": 3
"id": 13,
"interval": null,
"links": [],
"mappingType": 1,
"mappingTypes": [
"value": 1
"value": 2
"nullText": null,
"postfix": "",
"prefix": "",
"rangeMaps": [
"from": "null",
"text": "N/A",
"to": "null"
"repeat": "",
"sparkline": {
"full": false,
"show": false
"targets": [
"hide": false,
"refId": "A",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "OSPF",
"valueMaps": [
"op": "=",
"text": "DOWN",
"value": "1"
"op": "=",
"text": "Attempt",
"value": "2"
"op": "=",
"text": "Init",
"value": "3"
"op": "=",
"text": "TwoWay",
"value": "4"
"op": "=",
"value": "5"
"op": "=",
"text": "Exchange",
"value": "6"
"op": "=",
"text": "Loading",
"value": "7"
"op": "=",
"text": "FULL",
"value": "8"
"options": {}
"gridPos": {
"h": 3,
"w": 2,
"x": 20,
"y": 3
"id": 14,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Transmit"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"target": "SELECT TOP 1 OutPercentUtil FROM Orion.NPM.InterfaceTraffic WHERE NODEID=17 AND InterfaceID= 120 ORDER BY DateTime DESC",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
"gridPos": {
"h": 3,
"w": 2,
"x": 22,
"y": 3
"id": 15,
"links": [],
"options": {
"fieldOptions": {
"values": false,
"calcs": [
"last"
"defaults": {
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"index": 0,
"value": null
"color": "#EAB839",
"index": 1,
"value": 50
"color": "red",
"index": 2,
"value": 80
"mappings": [],
"unit": "percent",
"decimals": null,
"min": 0,
"max": 100,
"color": {
"title": "Receive"
"overrides": []
"repeat": null,
"targets": [
"refId": "A",
"target": "SELECT TOP 1 InPercentUtil FROM Orion.NPM.InterfaceTraffic WHERE NODEID=17 AND InterfaceID= 120 ORDER BY DateTime DESC",
"type": "table"
"timeFrom": null,
"timeShift": null,
"title": "",
"type": "gauge"
