I have 6 panels, (panel 1…panel6).
what I want to do is copy these 6 panels in json, so I will have 12 panels in total, and then slightly change these 6 new panels accordingly.
to do this I have to change the id "id": 2, in each panel.
is there anyhing else?
Also, what is the best way of editing the json file? is it in the browser?
I think i have to change the gridPos also:
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 1
"id": 4,
"gridPos": {
"h": 8,
"w": 12,
"x": 12,
"y": 1
"id": 5,
this is what my panel looks like:
"datasource": "halter-prometheus-tools",
"fieldConfig": {
"defaults": {
"color": {
"mode": "palette-classic"
"custom": {
"axisLabel": "",
"axisPlacement": "auto",
"barAlignment": 0,
"drawStyle": "line",
"fillOpacity": 0,
"gradientMode": "none",
"hideFrom": {
"legend": false,
"tooltip": false,
"viz": false
"lineInterpolation": "linear",
"lineWidth": 1,
"pointSize": 5,
"scaleDistribution": {
"type": "linear"
"showPoints": "auto",
"spanNulls": false,
"stacking": {
"group": "A",
"mode": "none"
"thresholdsStyle": {
"mode": "off"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 1
"id": 10,
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom"
"tooltip": {
"mode": "single"
"targets": [
"exemplar": true,
"expr": "rate(ifInOctets{ifAlias=\"devices\", network_name=\"2be6f728-c755-4d59-9069-a0f834ae63d0\"}[5m])",
"interval": "",
"legendFormat": "{{ifAlias}} {{ifName}} ifInOctets",
"queryType": "randomWalk",
"refId": "A"
"exemplar": true,
"expr": "rate(ifOutOctets{ifAlias=\"devices\", network_name=\"2be6f728-c755-4d59-9069-a0f834ae63d0\"}[5m])",
"hide": false,
"interval": "",
"legendFormat": "{{ifAlias}} {{ifName}} ifOutOctets",
"refId": "B"
"title": "devices(br0.104) - devices/collar wifi ",
"type": "timeseries"
7.5.7 -
recreate panels I already have in the dashboard for slight editing -
editing the json file, not using the gui -
What happened?
not working, may need to make more changes to the json config -
6 panel dashboard to go to 12 panels -
see above -
n/a -
no
