Is there a way to take a graph created in one dashboard and implement in another with out recreating the Graph from scratch?
Thanks?
Thanks?
Through the UI, click the panel title and then open the menu with by clicking the 3 horizontal lines icon on the left, and choose “Panel JSON”. This opens the JSON for that panel at the top of the page, so if the graph you’re copying is at the bottom you’ll have to scroll up. Select all the JSON from the text box, and copy.
On your other dashboard create a new panel, and repeat this, pasting the copied JSON into the text box.
