I am using 2 data sources ie Prometheus and Cloudwatch.
I want to create my own dashboard by clubbing above 2 datasources data in single dashboard of my mine( based on my requirement).
How can i copy one graph/panel in one dashboard to another ?
there is no easy way to copy a panel from one dashboard into another.
If you hit the panel menu then the small menu icon in the panel menu, then Panel JSON, copy JSON, then in the other dashboard add any panel. Go to the panel json view and paste the panel json.
I copied and pasted JSON but it shows no data. The panel in original dashboard is working fine.
Click on Panel->More->Copy
Add Panel in another dashboard , you would get an extra button to paste the panel
