Panel menu on touch display
Hello to all,
After a late update of my Grafana 9.0.7 installation to the latest version 9.5.1, I have a problem displaying only on devices with a touch screen.
The menu of modification, sharing, etc of the panels is displayed permanently.
I don’t have this problem on my desktop.
Is there a setting so that Grafana does not take into account the touch screen?
On a tablet :
chrome_mmKYOMbCfp
On a desktop no problem :
Thanks for your help !
Sorry for my bad english
Hi @razor83,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
What is the touch device e.g. Android, Apple etc?
Also, if I understand you correctly, you do not want the 3 vertical dots to be displayed on the touch device?
Hi @usman.ahmad,
All Android, my Oneplus 8T and a Lenovo small tablet.
I’ve tried Chrome/Firefoxe with and without desktop mode.
Yes you understood :slight_smile:
The 3 dot do not show on my desktop, only wen my mouse goes over a panel, but on touch screen they stay visible.
Thx!
Same behaviour here. The dashboard I built looks horrible now…
I’d be glad if one could hide the panel menu entirely
edit: this started with grafana 9.5.0. Downgraded to 9.4.9 and the problem is gone.
Hi @razor83 and @buesche,
So there is a workaround to hide those 3 dots so that it don’t get selected when viewing it on the touch devices i.e.
Goto that particular Dashboard → Settings → Permissions and select "view only for viewer and editor.
Then should do the trick.
More better approach is to use the Public Dashboards (link to documentation)
I hope this helps.
