using version 9.5.1 -
display dashboard in kiosk mode without panel menu -
display dashboard in kiosk mode -
What happened?
in desktop browser everything is working as expected - panel menu only appears when hoover over a panel - on mobile and tablet browser (Chrome version for mobile) the panel menu is always visible - see screenshot!!
panel menu shouldnt be visible -
no error -
