Modify Menu Grafana
I would like to modify the panel context menu in Grafana that includes options like “View,” “Edit,” “Share,” “Explore,” “Inspect,” and “More,” or specifically the “More” menu that contains options like “Duplicate” and “Remove.” Is this possible?
Some items are hidden based on user role (i.e. Edit won’t be shown for Viewer etc.).
But in general, this is possible only by editing .js files in the build folder. See an example in this topic:
What is your requirement for doing this what is the use case
I want to have a shortcut for coloring, for the different options without going through editing
