When selecting some operators in a WHERE clause the symbol does not get interpolated correctly into the query inspector. Manually fixing the query works fine, so does just typing the greater than symbol instead of selecting it, it’s just when you select the symbol from the dropdown it does not work.
Example:
Confirmed on both greater than and less than symbols.
Hopefully you already know that this bug was fixed in release v.4.6.2.
