I am currently running grafana with influxdB locally on my raspberry pi. I access via the browser using localhost:8086. I was wondering if there is anyway for me to share the dashboard with someone else even though it is running locally? I only want to share with permission to view the dashboard and not modify it. Of course until now i have had no success because all of the links to share are localhost.
You just need to open access to InfluxDB to the network range the someone
else is on and they can get the same data as you can.
Yes this is actually what I would like to do but im not too sure how.
Have you tried changing “localhost” in the links to the IP address of the
InfluxDB / Grafana (Pi) server?
Are you talking about someone else in the same network range as the Pi,
or someone else across the Internet?
I would like someone else to view it outside of my network.
I’m going to assume that means “from the Internet”, so you’re going to have to
allow inbound access to your Grafana server (the Pi) and that’s beyond the
realm of this support list - that’s a question of network access and port
forwarding, best asked on a general Linux support list.
