Sharing Library panel as part of sharing the dashboard
I have a dashboard which makes use of panels picked up from a Panel Library. But when i share the dashboard on to another system, it errors out as it is not able to find these panels. What’s the best way to copy the panel library as i am not sure where they reside. Also, is there a better one-click way of sharing dashboards which used library panels?
Error seen “Panel plugin not found: Name: “Instance Status - QA”, UID: “udmVAZknk”” on the grafana instance where i am trying to import the dashboard.
Hi @gauravk18
Yes I believe that this is a known issue re: exporting library panels. Here are two good resources:
See this related bug report
browse the library panel epic issue
