How to provision a library panel
Hi, I have been able to provision dashboards, and now I would like to provision a panel library, can anybody point me to the documentation? I’m not able to find the way to provision the panel libraries.
Regards.
In the provision folder there should be a sample one to get you starteeld with but
Check this out
Hi @yosiasz , I’m sorry but I’m not sure about your message, when you say there should be a sample, in the provision folder, are you refering to some repo?
by the way, in the link that you shared it, there are only three possible folders where I can put the library panel, and it seems that the folder should be /dashboards, can you confirm this?
Regards.
Sorry I meant to say in the folder of your grafana install. In my case it is here
So I should put my library panel in the /provisioning/dashboards folder?
Hi @micuentadecasa,
Were you able to resolve provisioning library panels?
I’m at a similar point as you were in August where I’ve provisioned my data sources and dashboards through helm but am still trying to discover methodology for library panels.
Seems it is not currently possible. There’s a GitHub issue to track this.
