I was just checking out the newest Features of Grafana 8 from the beta1 and realized the panel library. So great and nice solution.
Are there any plans to provision them form folder or create per API? Couldn’t find anything yet.
Best regards Dirk
Hi @zorkin82,
Yes, there are plans. There’s a lot of work being done on provisioning, which you’ll start to see in Grafana 8.1+.
Hi Matt,
thank’s for your response. That’s good to know!
Is this feature available yet. There are no docs on provisioning library panels yet.
Still looking for an update or guidance.
This is an issue we have been dealing with for multiple months.
We are provisioning all dashboards using git and have not been able to use library panels.
Relevant Github-Issue
