How to share a dasboard that uses the Canvas panel
Hello all,
I managed to create a network diagram using the Canvas panel. I’m having issues sharing the Grafana dashboard on a new instance:
  • The panel has a custom SVG, which I copied to grafana/public/img/icons/marker on the new server. It has the right permissions. This part works.
  • The fields do not show up, Grafana shows an error that says ‘Field not Found’. If I edit the field and re-select it I get the value back.
  • I shared the Dashboard with ‘Export for sharing externally’
Any hints/ ideas on what I’m doing wrong?
Thanks.
