11.5.2 - installed via kube-prometheus-stack helm chart, which wraps the official Grafana helm chart.
- What are you trying to achieve?
Share a dashboard publicly
- How are you trying to achieve it?
Using the official instructions
- What happened?
Multiple errors occurred:
- “Invalid panel id”
- Default URL is wrong (http + port instead of https URL)
- “Template variables are not supported”
Template: Node Exporter Full | Grafana Labs
Sharing would work out of the box with officially maintained dashboards from the Grafana dashboard Gallery.
- Can you copy/paste the configuration(s) that you are having problems with?
Nothing explicitly configured.
<docs/grafana/latest/dashboards/share-dashboards-panels/shared-dashboards>
(not allowed to post more than 2 links)
Overall, I am wondering if I am missing a configuration on the chart side (e.g. to fix the http-only share URL) and what must be done in the dashboards to make them work for public access.
