Using grafana 10.2.2 I’m trying to set the threshold using a “Config from query” transformation using a field of the data query to match the threshold associated with it in the config query. I used the example in the Demo “Transforms - Config from query” to simplify my real case.
https://play.grafana.org/d/Fc6gwV4nz/transforms-config-from-query?orgId=1&tab=transform&editPanel=9
In the data query I added a column which holds the ThresholdId used to match a specific threshold in the config query:
In the config query, I added a few threshold configurations:
The transformation is as follow:
But the threshold shown in the panel is not overridden
it displays the one that is defined in the panel configuration
Is there a way to make this work?
Any ideas/suggestions will be greatly appreciated!
Thanks
Paul
